Lleo joseph: Intercom/lock transformer
Old 11-20-11, 03:42 PM
My jeron model 5025 will not open the front door from any apartments. The Adams door strike operates ok when 24 volts is applied. There is 0 voltage at the door relay when an apartment door button is pressed.
Is there any thing else I can do before I consider installing a new box?
Is installing a new box a doable project for a maintenance person?
What problems may I encounter?
Any help would be appreciated
Old 11-20-11, 04:30 PM
ray2047's Avatar
What is the voltage under load on the secondary of the transformer?
Old 11-20-11, 05:07 PM
I would bypass the building wiring to test the unit. This would tell me if there was a problem with the building wiring or if there was a problem with the unit.
There can be all sorts of problems with low voltage wiring. Sometimes it is not installed properly. Someone just twists a connection together and does not use a wire nut. Then years later the connection stops working.
Or work might be done around a building which cuts or stretches a wire. A workman might have drilled into a wall or cut into a wall and cut a main wire. Or a wire can be strung very tight, then the building settles and eventually breaks the wire.
My tools for testing would be a schematic wiring diagram of the door opener unit,
A multimeter,
And a noise making continuity tester (sometimes wireless) is helpful to test the buttons from each apartment.
