8 GA wire for clothes dryer
Old 11-23-11, 03:50 PM
T
I am relocating a clothes dryer, and the existing outlet is too far away to be used, and there is not enough wire to re-route to where the new outlet will be.
I have some 8 GA wire left over from a previous job that is long enough, so I want to use it rather than buy some new 10 GA.
I just want to confurm that there are no problems doing this (and connecting to current 30A breaker).
Also want thoughts of surface-mounting a junction box and adding the extra 10' of 8 GA wire needed.
I presume the first choice is better (safer?).
Thanks for your help!
Old 11-23-11, 05:37 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
#8 is fine but:
What kind of wire? Do you mean cable not wire? If cable it must be 8-3 plus ground. Is the dryer receptacle 3-wire or 4-wire? A 3-wire circuit can not be extended.
Old 11-23-11, 05:46 PM
Tolyn Ironhand's Avatar
Received 348 Votes on 301 Posts
Also, is it copper or aluminum wire?
Old 11-23-11, 06:09 PM
T
Details
It's 3 wire (copper) with ground. NMD90, if I recall correctly (not at hand).
Old 11-24-11, 04:48 AM
W
Received 34 Votes on 31 Posts
Wire Gauges
I would not mix wire gauges in the same branch circuit.
Old 11-24-11, 06:13 AM
ray2047's Avatar
But is the original circuit 4-wire or 3 wire?
Replies based on US code but Canadian should be similar.
Old 11-24-11, 08:02 AM
T
Hi Ray:
The original circuit is 3 wire red/white/black plus ground. New is the same.
Tom
Old 11-24-11, 08:20 AM
CasualJoe's Avatar
Received 111 Votes on 98 Posts
That would be considered a 4 wire circuit. You can extend it for your dryer with additional #8 or #10 NM cable as long as it is protected by no more than a 30 amp breaker. Although it isn't always adviseable to mix wire sizes, it wouldn't be a code violation. As Ray stated
