Multiple Grounding Rods
Old 11-26-11, 09:09 PM
H
I have a hillside property with an ungrounded switched light in the yard. I have tapped the light and installed a box with a GFCI outlet so that I can control other things with the switch. Problem now is that this is an ungrounded outlet.
Should / can I pound in a grounding rod near the outlet and ground it or will this pose a dangerous situation?
Any suggestions? Thanks, Eric
Old 11-26-11, 09:35 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
No. By US code you must run the wire back to to the breaker panel ground. The GFCI is the best you can do with out running a wire to the panel. It would probably be as easy to just run a new cable unless this is conduit.
Old 11-27-11, 02:11 AM
pcboss's Avatar
Received 83 Votes on 71 Posts
Ground rods play no part in the operation of a receptacle.
Old 11-27-11, 07:04 AM
Z
Received 102 Votes on 95 Posts
If you use one of those stickers, "Ungrounded" that came with the GFI, you're by code good to go. Since you'll likely just be plugging lights or other things out there that don't really need a ground, you should be good to go.
