3 Speed Motor Wiring
Old 12-02-11, 04:35 PM
CircuitBreaker's Avatar
Received 38 Votes on 36 Posts
I found a fan with a broken control panel (Digital) and I would like to put a manual switch in it (Which I happen to have from another junked fan)
Anyway the fan was a Honeywell and is made of metal
The motor has 7 Wires coming out of it
I applied power to the fan before I took it apart and it works but the LCD/Timer was broken
Anyway I looked at the PCB where the wires went and
Red = High
Yellow = Med
Brown = Low
Gray Goes to a Capacitor
White and black are nutted to a white wire that goes to the Capacitor
The motor is P/N: 11MAM160318 (Which returns no results on Google)
My speed switch has 5 wires
1 2 3 ACH ACN
Is there a way to make my fan work?
I know nothing about wiring multi speed motors but I know how to wire things up safely
Thanks
Old 12-02-11, 06:04 PM
F
Received 36 Votes on 28 Posts
Where is the seventh wire? You only listed six colors.
Do you have a multimeter?
Old 12-02-11, 06:14 PM
I do have a multimeter
sorry I missed a wire
There are 7 wires
Red Yellow Brown Gray White Black and another black
Old 12-02-11, 06:31 PM
F
You have already determined that the red, yellow and brown are the three speed wires so you can ignore them for a while. Do you know where the remaining wires were originally connected to the control panel?
Exactly how is the capacitor wired?
Set your multimeter to low ohms and connect one lead to the ACN wire on the new switch. Connect the other lead to the ACH wire and then step the switch through all of its positions. Note which positions (if any) show continuity. Do this also with the 1,2 and 3 wires noting any position that shows continuity to ACN. Then move the multimeter lead from ACN to ACH and do the same exercise and note which wires and switch positions show continuity to ACH.
Can you post a picture of the motor with the leads and capacitor?
Old 12-02-11, 09:19 PM
Here are some images of the motor and the capacitor
I don't remember where the other wires went
I also can't find my switch
Old 12-03-11, 12:47 PM
F
Please move the wires so that they are not crossing over each other and take the red, yellow and brown completely out of the picture.
Also, I see only one black wire but also a bluish-green wire.
Old 12-04-11, 10:02 AM
Sorry about that Furd
Here are some better pictures
Old 12-04-11, 02:25 PM
F
It appears that there is a short "stump" of white wire from that connector that also has a black, white and bluish-green wire. That MAY be the neutral lead but the inclusion of the bluish-green and black is highly suspect.
The black that is connected to the green is also suspect. It seems that using a standardized color code meant nothing to the manufacturer.
I'm sorry, I cannot help you.
