Adding a sub-panel outside
Hey guys currently i have maxed out all my exterior plugs with christmas lights and wanting a light show next year i have a problem. Heres how my current boxes are.
main box 200 amp --> 90 amp inside box
90 amp a/c
seeing all my boxes are full (cheap contractors) i was thinking of adding another box for my lights. I dont know if the a/c unit needs a dedicated box or not but i was thinking something like this
main box 200 amp ---> 90 amp inside
150 amp sub
90 amp a/c
all the breakers for extra outlets outside would be in the 150 amp box. it would be nice if the a/c unit didnt need a dedicated box and i could just run the a/c out of the 150 amp box also.
i know it would be easier to just upgrade my 200 amp box with a 6 or 8 slot one but then i would have to pull my meter. thats a headache i cant deal with on the weekends anyways. another reason i need this is i dont have a spot for my generator when the lights go out pphhh. so does everything look good or should i lower the 150 amp?
90 amp a/c
150 amp sub
90 amp a/c
The A/C circuit is 240 volts only. There is no neutral.
How much seasonal lighting do you plan on installing?
guess i forgot to mention the a/c box is 3 feet from the main box (both outside). so pulling all new wires with the new box from the main is no problem. for lights i think we have around 1000 lights and afew blow ups next year i am looking for around 6000 or so and maybe more the next
Is it a 90A A/C Disconnect or subpanel? 90A seems to be a lot for an A/C which is why I ask.
You also have to confirm that the manufacturer of your 200A panel makes compatible 150A breakers. Not all panels will accept breakers over 100A.
