Old House with weird Wiring (3-Way Switch)
Old 12-05-11, 08:19 PM
CircuitBreaker's Avatar
I have a friend who just moved into a house built in 1927 and I am trying to replace a couple of switches (3Way) and there is only a 14/2 (No Ground) but it is of the "Romex" Type
I found a diagram on the web of what I am dealing with
I am just want to get the light working but it seems that this is no longer wired to code as the neutral is switched is there a way to get this to code without rewiring (I only need one location as the two switches are only about 10FT apart anyway)
Old 12-05-11, 08:49 PM
At the location you want to eliminate the switch connect the C to the neutral wire. At the switch location connect a regular switch from C to the "hot" line. Insulate the unused wires.
Old 12-07-11, 12:58 PM
Thank You Furd that worked perfectly
