light switch/outlet problem?
Old 12-06-11, 09:26 PM
first of all the wiring in my home is aluminum,in my bedrooms i don't have ceiling lights, i have a light switch that runs the wall outlet meaning when i turn light switch on the lamps turn on. my problem is i replaced all the outlets in the bedroom, now when i turn the switch on the lamps plugged in outlet dont work,but the outlets have power, i made sure the connections in the outlet are correct,i connected the 2 white wires to the silver screws and the red and black to the bronze screws and ground to green screw. why wont the switch work the outlet now?
Old 12-06-11, 09:34 PM
ray2047's Avatar
Was the tab broken between the brass screws on the okd receptacles. If so did you break the tab between the brass screws?
Safety Question: Did you use Co-AL (Cu-Al) receptacles and antioxidant grease?
