Reload this Page >
Oven installation says use 8 gauge wire, but it is a 30 amp circuit
Old 12-12-11, 05:19 PM
My ikea whirlpool installation guide says to use a 30 amp circuit for models rated 7.2kw and below for 240 volts. The oven I have says it uses 5.1kw at 240 volts, so I am planning on using an available 30 amp circuit already at my board.
It also says in a warning statement to use 8 gauge solid copper wire in the installation guide and on a sticker taped to the wires coming out of the back of the oven.
Here is were it says the info:
Whirlpool Installation Instructions - 8303102-004 - YouserGuide
Whirlpool Installation Instructions - 8303102-005 - YouserGuide
I'm planning on using 10-3 however, because it is only a 30 amp circuit and it is much cheaper and easier to junction. Is this ok? I am thinking this is ok because of what I read on this post:
http://www.doityourself.com/forum/el...en-wiring.html
Thanks,
Old 12-12-11, 06:25 PM
CasualJoe's Avatar
Received 43 Votes on 35 Posts
The specified "8 gauge solid copper wire" looks like an error to me, I'd also use 10-3 NM B cable. When was the last time you saw #8 solid copper wire other than bare ground wire?
