OUtside GFCI outlet goining bad.
Received 0 Votes
Outside GFCI outlet going bad.
So my brother installed a GFCI outlet outside of his home. It has a bubble cover over it for in use protection. He says that it has gone bad twice so far and had to be replaced. Seems like every 2 years. The outlet appeared to be corroded when removed from the box. He had another outlet installed with on the other side of the house and it has been fine since 2006. Any ideas on what is killing this GFCI? Are there better grade versions available than stuff from the big box?
I didn't realize you couldn't just use any gfci outdoors.
