Disconnecting a Light Switch from a Duplex Plug Outlet
Received 0 Votes
In all of the bedrooms of my house there is one outlet that is connected to the light switch so that it only works when the light is on. It was like that when we bought the house and I want to change it so that the outlet works all the time regardless of whether the lights are on or not. Can somebody please give me directions on how to do this? Thanks
The code requires a switch controlled lighting outlet in habitable rooms. You will need to keep the switched receptacle unless you install other lighting like a ceiling fan with a light kit or other lighting.
