generac 7/8kw generator
Old 01-02-12, 02:01 PM
I going to have installed this generator. My panal box and gas are
on separate ends of the house. Can pre wired connections be spliced in order to run wire instead of black pipe for gas? generator is very heavy and would not like to have to move it.
chuck
Old 01-03-12, 11:06 AM
What so you mean by pre-wired connections? The generator is normally installed close to the electric meter along with a transfer switch.
Old 01-03-12, 03:52 PM
I see no reason why the power and signaling cables can't be run across the house (inside or outside - presuming you use the correct wire). Nothing is really pre-wired in an installed generator, so you shouldn't have an issue.
