Restaurant power supplys
Received 0 Votes
Hi everyone,
I was wondering if anyone can tell me what are the typical
power supplies found in restaurants ? for example, do all restaurants have 208v 3 phase outlets or 460v 3 phase?
thanks in advance,
jason
thanks in advance,
jason
Received 0 Votes
The most practical system for a resturant is 3-phase , 4-wire , 120 / 208 volts. This provides---
120 volt 2-wire circuits for liting , receptacles , 120 volt appliances, and 120 volt single-phase motors.
208 volt 2-wire circuits for for 2-wire 208 appliances and 208 volt single-phase motors
120/208 volt 3-wire circuits for 3-wire 120 / 208 appliances
208 volt 3-wire circuits for 3-phase motors.
I am on the same page as Joe is there is no specfic voltage requirement in the resuarant.
Now for the uilziation of the incomming power source will varies a bit depending on the POCO grid and what they will provide the supply to the place.
And service size will varies a bit as well they can be anywhere from single phase 120/240 volt 200 amp and up plus three phase service will typically go 400 amp and up depending on the layout and power requirement of that restuarnt.
I just have one done not too long ago by using the European specs that place have 630 amp service 415Y240 volt system
PATTBAA.,
I know you say "208 volt 3-wire circuits for 3-phase motors."
There is also a 208 3 Ph water heaters as well it a pretty common item if you have three phase power avaiable.
Justin.,
I will give you a straight answer that voltage is common used in European area., 415Y240 is proper term.
Merci,
Marc
PATTBAA.,
Justin.,
240Y416 (no clue why)
Merci,
Marc
Very good answer, Marc. If you are thinking of opening a restaurant, the important thing is to find out what service the POCO will provide you and give this information to the engineer designing your restaurant so the proper electrical system can be designed for the equipment. By all means, don't buy any equipment without consulting the POCO and engineer on the job as it all must have the proper voltages specified.
Received 0 Votes
Restaurant power supplies
Thanks guys,
I'm in the drain cleaning business and have been looking at a piece of equipment that requires 3ph/460v. so now i know i can't rely on having adequate power being available.
thanks again,
Jason
thanks again,
Jason
I have no idea what type of drain cleaning equipment would require 3 phase, but if it is also available in single phase 240 volt, I'd go that route. Even if a restaurant is supplied from the utility with a 277/480 volt service, you can be assured there will be a transformer providing 120/208 volt 3 phase service or single phase service within the restaurant too (to provide for 120 volt receptacles) and that either of those services would operate a 240 volt single phase piece of equipment.
