Bathroom, adding GFCI to Switch
Old 01-08-12, 11:52 PM
P
So i have a bathroom with a single gang box with 2 switches, one that controls the lights and another that controls an exhaust fan. I would like to add a gfci next to this. I have installed the 2 gang box and have the 4 wires from the prior combination switch in it ( Black, Red, White, and Ground ). Wires are 12 gauge and everything is 15 amp. How can i wire this so that both switches still operate the lights and fan independently?
GFCI:
15-Amp Light Almond Slim Tamper Resistant GFCI-R06-X7599-0KT at The Home Depot
Combination Switch:
15-Amp Light Almond Combination Double Switch-R56-05224-2TS at The Home Depot
Old 01-09-12, 12:52 AM
ray2047's Avatar
Received 15 Votes on 13 Posts
Your description sounds like a switch loop. You do not have a neutral for the GFCI. You will need to run a source of power to the box for the GFCI. That could be either from another receptacle or replacing the 3 conductor cable from the fan with a four conductor cable (or ENT with four single conductors plus ground).
Assumes you told us all the wires in the switch box.
Old 01-09-12, 05:36 AM
pcboss's Avatar
Received 146 Votes on 129 Posts
I agree with Ray that this sounds like a switch loop. Also a new installation should really be a 20 amp circuit for the receptacle.
