European to American help
Old 01-23-12, 02:13 PM
I have some European appliances, and I need them to work asap. I bought a step up/ down transformer specifically designed to convert European to American and vice-versa. The appliance says it runs at 230 volts. The transformer has various inputs. I have tried both the 220 & 240 v inputs, with the 110 v output. The transformer is rated for 500 Watts, and the appliances run at about 300. Why isn't this working? Also note that the instructions say that if you live in a 110 v country then the input should be selected at 220 v if that helps differentiate between the "output" and "input"
Old 01-23-12, 02:28 PM
the_tow_guy's Avatar
Our resident expert on Euro power is marc (french277V); hopefully he'll be along to help shortly.
Old 01-23-12, 03:08 PM
You have now a line voltage of 120v correct? If so, your line needs to connect to the input, and the appliance to the 240v output. I think you just provided your appliance with 60 volts?? It's likely any clocks on the euro appliances may not keep correct time.
Old 01-23-12, 05:03 PM
ray2047's Avatar
What appliance? If it is pure resistance it might work but if it has a motor you have problems because of frequency differences.
Old 01-23-12, 07:22 PM
CasualJoe's Avatar
In addition to the frequency problem, it appears to me you are using the wrong input because I believe the European appliances would require 220 volts.
That can't be right, I don't think European appliances would run on 110 or 120 volts. I believe you are trying to hook it up backwards.
I think if you determine the correct output you need, the correct input will be obvious. In other words, if you need an output of 220 volts for European appliances, choose the 120 volt input while you are here in the U.S.
