half of a circuit is dead
Old 01-26-12, 01:45 PM
heard my breaker trip the other night so i reset it and everything worked fine, the next day i had to reset it again only this time half the outlets and lights were not working and the breaker doesnt trip anymore....by the way ive changed every outlet on this circuit and still no luck....any help is greatly appreciated
Old 01-26-12, 02:00 PM
by the way i have replaced all 7 outlets on the circuit and its only 2 outlets and kitchen and dining room lights that arent working
Old 01-26-12, 02:32 PM
Justin Smith's Avatar
Look for a burned or loose connection, possibly in the kitchen and dining room lights.
Old 01-26-12, 04:01 PM
no sir...their is no physical evidence of burned or loose connections
Old 01-26-12, 04:27 PM
ray2047's Avatar
If any of the wires are back stabbed move them to the screws.
Old 01-26-12, 06:41 PM
no theyre all around the screws...i never mess with the backstabbers
Old 01-26-12, 07:08 PM
ray2047's Avatar
Are there any lights either working or not working on the breaker?
Old 01-26-12, 09:03 PM
yes the lights in the den are working, the lights in the kitchen and dining room are not
Old 01-26-12, 09:19 PM
ray2047's Avatar
That may be a clue. You are going to have to open the lights and switches and check every wire nut connection. Remove each wire nut, check the wires and inside the wire nuts for damage. (I'd probably just replace them with new ones.) The problem may be in the last working light or switch before where the problem begins or the first bad device.
Old 01-26-12, 10:28 PM
all lights are checked sir and looks good... i already replaced all the switches...and still no luck
