GFCI receptacle to 3-prong?
Old 02-04-12, 08:20 AM
Question GFCI receptacle to 3-prong?
When my house was built 7 years ago it had a screened in
porch with a GFCI outlet. Over the course of time a deck was
built outside and the screened porch was enclosed into a home
office but the GFCI outlet remained. Lately that outlet has
become, for lack of a better word, unstable. It trips during
thunderstorms, if the TV is turned on while a light is on. As you
might imagine this is not a good thing for a home office with
computers, a modem, a router, etc. My question is, since the
area is no longer 'outside,' can I replace the GFCI receptacle with
a regular 3-prong outlet? Thanks. Darlene
Old 02-04-12, 08:29 AM
ray2047's Avatar
since the area is no longer 'outside,' can I replace the GFCI receptacle with
Only if the receptacle does not feed a receptacle that requires GFCI protection.Is there one cable or two in the box? If two where does that cable go? If that device needs GFCI protection you could add the GFCI protection there and be able to remove it from the receptacle located inside.
Old 02-04-12, 08:38 AM
Thanks, Ray. I will check the box. If it's one wire, I'll change it myself. If it's two, I'll call an electrician! Thanks, again. Darlene
Old 02-04-12, 08:42 AM
SeaOn's Avatar
If it’s tripping because of the above, would this indicate another problem “may” be in the works???
Bet it has two cables-if the above problem is happening at the GFCI receptacle outlet
Place your bets here….LOL
Old 02-04-12, 09:33 AM
Smile
Gfis's are solid state devices and over time can become unstable (trip without any particular reason). I always have a new one handy and see if the resultant is same with the new one first.
Old 02-04-12, 10:08 AM
Justin Smith's Avatar
I think your GFCI might have been damaged. Did you try replacing it?
Old 02-04-12, 01:15 PM
CasualJoe's Avatar
In addition, I would recommend a whole house surge suppressor be installed at the main electrical panel.
