What to do with my unused wires?
Old 02-04-12, 10:03 AM
I recently replaced a dimmer for my basement and when I removed the old dimmer, I found 2 live wires behind it(nothing on their ends, just freshly snipped). They are somehow connected to my kitchen breaker, while the wires I use for the dimmer are on my basement breaker. I'm not sure where their source is from. Can I just twist them into the wires I already have going to the dimmer? How do I safely end them? Thanks for the help.
Old 02-04-12, 10:40 AM
pcboss's Avatar
Without knowing where they go I would just screw a wire nut over each wire end.
Old 02-04-12, 10:48 AM
So one wire nut on each wires(black and white)? And should I strip a little off the ends before I put the nut on? Thanks again.
Old 02-04-12, 10:53 AM
SeaOn's Avatar
I agree with pcboss. Yes. one wire nut on each, and no, you do not need to strip them. Just make sure the wire nut does not fall off.
Old 02-04-12, 10:55 AM
Great, that sounds like an easy fix. Thanks.
