Trying to Determine Plug Type for Dryer
Old 02-04-12, 05:48 PM
Hi All,
I would like to replace an aging stacked washer/dryer "laundry center" with a modern configuration, but to do so I need a newer 220v outlet. My current machine (specs below) does seem to be plugged into to such an outlet, but I cannot tell if it is a 3 or 4 prong configuration (and, due to space considerations, I cannot move the unit to unplug it). The building was build in 1986 and the washer/dryer is about 12 years old. I have included the following images:
[IMG]<a href="http://s1062.photobucket.com/albums/t488/wcladley/?action=view&amp;current=02042012010.jpg" target="_blank"><img src="http://i1062.photobucket.com/albums/t488/wcladley/02042012010.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s1062.photobucket.com/albums/t488/wcladley/?action=view&amp;current=02042012007.jpg" target="_blank"><img src="http://i1062.photobucket.com/albums/t488/wcladley/02042012007.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s1062.photobucket.com/albums/t488/wcladley/?action=view&amp;current=02042012003.jpg" target="_blank"><img src="http://i1062.photobucket.com/albums/t488/wcladley/02042012003.jpg" border="0" alt="Photobucket"></a>[/IMG]
Here is a direct link to the pics, in case the embedding did not work properly:
Pictures by wcladley - Photobucket
Here are the specs of the current model:
Mfr: Kenmore
Model# 110.88752792
Type: DT/T-ELE-2406021-FM30
120/240V 21A 60Hz
Any help or suggestions would be greatly appreciated.
Thanks!
Old 02-04-12, 06:05 PM
Justin Smith's Avatar
You have a 3-wire, 10-30R receptacle.
Old 02-04-12, 06:09 PM
pcboss's Avatar
Given the age of the intall I would expect it to be wired with 10-3 with ground cable. This would allow the usage of a 4 wire receptacle.
