Sub panel
Old 02-10-12, 07:06 PM
Sub panel
Hey,
Got a friend that is installing a sub panel and a Master electrician told him to run 6/2 with ground . He ran the wire and had it inspected (it passed) . I was talking to him about wiring it up I told him he needed 6/3 with ground . I worked in Hvac and appliances in the past and have been shocked by 6/2 setup because the ground/neutral wire open up and power was feed back through the ground . Using your ground wire as a neutral does not set well with me , and having a 10 ga wire (smaller than the two hot wires) seems like another issue . Neutral wire should also be coated (if I remember right). He called the inspector and found out I was right about it being a code violation on several points. Now that they know it he has to change it . The electrician then called him and told him he has been doing it for years and never had a problem. Was this EVER allowed by code would you suggest changing after it was passed by inspection? I would never do this at my house ...
Old 02-10-12, 07:29 PM
pcboss's Avatar
Are you saying they ran 6-2 +g for a 120 or a 240 subpanel? If I understand you they only ran two hots and are using the bare grounding conductor as the neutral. What is being used as a ground?
Three wire feeders were allowed to detached structures when certain conditions existed. The neutral was again bonded like a service panel. The NEC does not allow this anymore. New feeders need to be 4 wires.
Old 02-10-12, 07:38 PM
They were using the Bare 10 ga as both ground and neutral..... It was going to be 240/120 sub panel (both available) . You said in some condition in the past the NEC would allow a three wire connection ..... in that old case could the Neutral be a 10 ga on a 50 amp service panel ?
Old 02-10-12, 08:06 PM
CasualJoe's Avatar
6-2/G NM cable has never been allowed as a feeder to a 120/240 volt subpanel as far as I know.
Old 02-10-12, 08:11 PM
CasualJoe's Avatar
It's sad, but in some areas, the inspectors don't know what they are looking at and don't have a clue about the NEC. In other areas, inspectors are known for drive-by inspections. Even sadder is that some electricians don't have a clue about the NEC either and that is using the term electrician loosely.
Old 02-11-12, 06:47 AM
Tolyn Ironhand's Avatar
I am wondering about the credentials of this "master" electrician. This panel can only be used for 120 volt circuit. 1 hot, 1 neutral (full size) 1 ground.
Old 02-11-12, 07:32 AM
CasualJoe's Avatar
I was wondering about the same thing.
