Easye1644: Finding pool light switch
Received 0 Votes
I purchased a foreclosure and everything was as is. So it's been a challenge learning to operate a pool with no help or manuals. I have looked everywhere for the pool light switch, but can't see it in any obvious place. I've found the junction box. Any ideas on where to c look or how to add another light switch. Thanks.
Did you make sure the lights are good? You can ohm them out with a meter.
You should be able to trace the cable/wire to some place where there would be a switch. It very likely might be inside the house. You will have to find where the hot comes from in order to interrupt it for a new switch, so you could also trace the cable going from the electrical panel and see where it goes to maybe locate the existing switch.
