How to get wiring under house
I am going to add a dedicated electrical circuit for my home theater. and I would like to run the wiring under the house(easiest). I'm going to have an electrician look at my work before connecting everything to make sure it's ok. I dont know how to get the wiring to my panel in the garage. The panel is recessed in the drywall and no access to under the house( because of foundation below it and bottom plate of framing) . On the back side of the all the breaker is mounted in is the dining room and hardwood floors. I may not have described the problem accurately, so ask questions as needed please. Thanks
crawl space. however it sits in an exterior wall(wall between garage and house, because house sits about a foot higher). So, it is bottom plate on top of foundation. And it is a two story house(lower level)
How high is the crawl space? Do you have an access opening. If no access opening and it is more then eighteen inches I'd make an access opening. If not practice to do from the outside in the vertical foundation wall I'd make an access in the floor of a closet.
I have an acccess, and plenty of room under neath, but no way to get the wires through the bottom plate under the breaker box because it sits directly on the foundation. Thanks
Your best bet is to remove the sheetrock, carefully under the panel to the floor. Two vertical cuts on top of the middle of the studs. Once you remove this sheetrock, you will be better able to see what your options are. Although the wall you are describing for the garage is sitting on concrete, the adjoining structure, most likely is sitting on a rim joist which will give you probably 8" or so of space to bring your wiring from the crawl to the panel area. You can replace the sheetrock and finish it out or make a permanent "panel" of it for future access.
Add: gosh I like it when two minds react at the same time with the same response.
If I understand correctly, the issues hte OP is having is getting from the crawlspace into the wall where the panel is, and accessing the bottom of the panel to bring the wire in.
Remove the drywall underneath the panel so you have enough access to get your hands in there to work. If you are careful enough during your removal, you can replace the same piece of drywall, then tape and mud the seams. It's important to seal the seams to prevent any vehicle fumes from entering the building and to maintain the fire barrier.
If you cannot get good access from below to drill a hole through the subfloor and into the wall cavity, use one these bits from above through the hole you made under the panel: 9/16 in. x 54 in. Screw Point Flex Drill Bit-53718SEN at The Home Depot It will probably be much easier to locate the hole when drilled from above anyway. The bit is well worth the price.
Permit
Recommmend you get a Permit, yes you would have to pay for it and it would be about the same as having an electrician inspect it. This way you know it is up to code just in case something happens, I remomodeld my Kitchen and had to go the the subfloor for my Island back out ouf the house through crawl space vent, used electrical counduit outside the hous for a little cause the garage was on a slab. Housing inspector very satisfied. Als makes my insurance co happy.
