Entire house has power but nothing is working...
Received 0 Votes
Ok so me and my fiance were in the basement replumbing the house when his sister who lives on the other half(a duplex) came over to let us know all of her power had gone out. My fiance went to look at the breaker box and the door shocked him. All of the breakers are on and meters are reading it has electricity, the same with all of the outlets/lights in that side of the house, they have power but nothing works. The only room that was working was the bathroom and we found a glade plugin smoking in it and the light was on and we went to do something else and came back and the light was off. I could understand there being an issue with just 1 or 2 outlets but the whole half of the house is out! Any ideas?
Received 0 Votes
The side we are plumbing is on a seperate breaker altogether, seperate side as well. We are thinking maybe removing one of the pipes we may have skimmed and exposed a line from the other side? The other side of the house has no plumbing though so we don't know whats going on
His sister lives in the other side of the duplex that has electric, but no plumbing? Is there an outhouse in the back yard? I didn't know there were many homes left in this country in the 21st century with no plumbing.
Received 0 Votes
CasualJoe we just bought the house, apparently the other half hasn't even been used in over 60 years. I don't know why there is no plumbing on that side unless it was removed when this side was updated but it is gone. We share the one bathroom in the house that works since both sides are opened up to each other.
We discovered something else weird last night as well. While doing the plumbing shortly after the power went out on the other half one of the plumbing pipes shocked me. We discovered all of our heating ducts and water pipes were electrically charged. We believe it has been like that for some time though not just last night because there have been numerous occassions that we had breakers off on the hot water tank and still getting a slight shock while working on it. We used a tester on the heating ducts and tripped breakers to find out that the one that was charging the pipes and ducts was on his sisters side as well.
If the power company finds nothing wrong on their side of the meter you need to call an electrician immediately. This not a DIY project because of the potential danger. I would suggest staying with friends or at a hotel till it can be corrected. It takes only a small amount of electric to kill.
Breaker Off
This is late, but if you haven't yet: CALL THE POWER COMPANY! They will check their side for free and 24/7. Tell them you are getting shocked by anything metal in your house. I'm sure they will be there in less than 1/2 hour.
Received 0 Votes
Ok so after reading all of the posts this morning about calling the power company I called and they showed up like 20 mins later. After looking at the wires they said that it is the neutral outside of the house. Water leaked into the outside box and the guy said when water hits the aluminum wire it just disintegrates. He said it had run down the wire and into the breaker box inside and that the whole service needs replaced and upon leaving took the meter with him, said that he couldn't risk something happening by leaving it on. The side we are on is on a total different service so we don't have to worry about that just now we have to share this side with his sister since she obviously can't stay on the other side now. My fiance worked in an apartment complex for 10 years doing maintenance so he has installed services and rewired quite a bit so he is going to just rewire the other side over again, upgrade the service to a better one and just basically redo that whole side. As for a ground wire turns out there never was one since we bought the house. For us to get the appraisal they had to fix a few things and in the process had cut the ground at the breaker box.
