four way switch question
Received 0 Votes
When wiring a four way switch can the source and the run to the light be at the same switch or does the source come in at one switch and then the run to the light at the last of the three switches?
Also can any of the three switches be a dimmer switch? Thanks again for any help.
If you run the required number of wires you can have whatever you want. It is easiest to first draw it out on paper and then you can easily see what changes you may need to allow for the desired wire run.
Some three-way dimmers can be used in three and four way circuits.
The dimmer needs to be at the location of a 3 way switch. I have never seen a dimmer that would work where the 4 way was located.
There are many ways to wire a 3 way setup. If you can provide more detail perhaps a better plan can be given.
I chose the Pass & Seymour because they were cheap, had good range, and were backwire-capable.
One thing to keep in mind with most 3-way dimmers is that if it's not totally OFF or at full brightness, the other toggles will only turn the light OFF or set it to the brightness of the dimmed toggle. I think!! Too lazy to check it out right now.
Yes, with a single dimmer the other switches will only be able to select from "on" and whatever the dimmer is set to. If you want full control from all switch locations you need an electronic dimmer with remotes.
MDI06-WAL > Mural
MDI06-WAL > Mural
