Continuing power through two light switches
Received 0 Votes
I have power coming into a light switch box. There are two switches, one powering a porch light, the other powering an overhead interior light. I am needing to continue power to an outlet after these switches.
This is what I've come up with. Will this work? Any better way to do it? I have a hard time believing all those wire nuts will fit into a 2 gang box.
Power seems to come in at the light from your diagram. If that is true there is no neutral at the switch assuming only a two conductor (plus ground) cable between the light and the switch. How does neutral get to the receptacle? You can't have a neutral and hot from different cables.
If the line feed is coming into the switch box, you should need only three wire nuts at most - one for four black wires - the hot wire, the feed for the new receptacle and two pigtails - one for each switch; another for four white wires - the line feed, the receptacle feed and each of the two light fixtures. All of the grounds - and there be as many as six of these if you bond the box plus each switch - go in the third wire nut, or a copper crimp connector.
Six wire nuts might fit in a 2-gang switch box behind two single-pole switches, but would you want to do that?
Received 0 Votes
Here's an updated diagram. Look correct? And what would be the easiest way to tie 6 grounds together with the least amount of clutter? I'm thinking maybe the copper crimp connectors, though I've never used those before.
Updated:
Updated:
Yep, 'at's what I'm talkin' about! To reduce box fill you can use a (one) copper crimp connector. Or you can just wire-nut them. You'll only have six wires if you need to bond the box and decide to bond each switch with a separate pigtail. Even then, you'll only have six 12 AWG wires if your circuit is 20A, and six 14 AWG if it's a 15 amp circuit. Six # 12s fit nicely in a Big Blue or a big grey wire nut, and that should fit nicely inside the box if you lay it horizontally across the back, either above or below the location of the switch bodies.
