switch tests fine but only 6V when load applied
Old 04-07-12, 09:45 AM
I have a bathroom fan switch that tests fine with a continuity tester but when a 120V load is applied, I'm only getting 6V out of the switch. Is the switch bad?
With the 120V load applied and the 6V at the switch, I test the load at the fan and I show nothing. If I pull the leads off the switch and short them together, I get 120V at the fan.
Should I replace the switch?
-Mike
Old 04-07-12, 10:15 AM
ray2047's Avatar
From your results that is what I'd try first.
