240 V 3 Prong to 4 Prong
Received 0 Votes
Hello All,
Thanks in advance for any help you're able to provide me. I broke a couple of common rules because I was rushing, so I ask your pardon up front.
That said, I went from a 3-prong 250V/50A range receptacle to a 4-prong 250V/50A.
Configuration for the old receptacle is the vertical slot is the ground, and I have 2 diagonal slots at 125V each. New 4-prong configuration has the 3 vertical slots, and one circular one.
I shut off the circuit breaker and had the wires detached from the old one before I remembered to annotate the proper wiring configuration for the hot wires. The ground is self-explanatory - goes on the circular slot.
Could somebody please clarify how to identify which slots the red/black and the black wire need to go to on the new receptacle? My concern here is proper phasing. Unfortunately, given my work hours I don't have an electrician available to come out in the middle of the night, and given recent crime in the area...it's impractical to get somebody to come out.
Again, thanks in advance for any help you're able to provide.
You need four wires, two hots, one neutral, one bare or green*. It doesn't sound like that is what you have. If you don't have those four wires you will need to go back to a three prong receptacle and convert the dryer to a three prong cord set or run new wiring.
*Metal conduit continuous to the panel an be used instead of a green or bare ground wire.
Received 0 Votes
Sure thing.
Model is the GE JBP66DMBB.
Link to manual (from the manufacturer's site) is:
(Use and care)
http://products.geappliances.com/Mar...49-80632-1.pdf
(Quick Specs)
http://products.geappliances.com/Mar...jbp66dm_r2.pdf
(Installation Instructions)
(Use and care)
(Quick Specs)
Thanks for the info. I wasn't second guessing you. Sort of for my own info, I just wondered if this type of unit allowed 3 wire installs. Their instructions are pretty clear on both 3 and 4 wire installs.
I'm pretty sure I've read here that there are some out there that do not allow 3 wire. In fact I remember one poster that had to return a big fancy combo range for a different model because he only had a 3 wire supply.
