Questions for rewiring a garage
Received 0 Votes
Renovating my attached garage, walls are open. Using the space as part workshop, part car hole. Will fully drywall/insulate the walls when finished.
1. From a code standpoint, can I put receptacles as high or as low as I desire? (ie can I put a double gang box 3 feet off the ground to energize power tools?)
2. Since this environment will be dusty and chaotic, are there any particular plugs/plates/etc I should use?
3. I only have one 20a circuit powering the entire garage, adding another circuit would be too painful. From a code standpoint, is there a restriction on the number of receptacles I can install? Not to get too in-depth but most of the loads will only be temporary (garage door opener, attic fan, power tools) however it would be nice to spread them across 8+ receptacles for accessibility and portability, is this OK?
Any other general recommendations for workshop wiring?
Thanks.
Thanks.
Height is your choice. There is no limit to the number of receptacles. The receptacles need to be GFCI protected either by a GFCI receptacle as the first receptacle or a GFCI breaker. Lights do not need to be GFCI protected.
You CAN install receptacles as high as you desire but they must be a minimum of 18 inches above the finished floor in a garage. If you have any lights that are cord-and-plug connected such as fluorescent "shop lights" utilizing receptacles in the ceiling the ceiling-mounted receptacles DO need to be GFCI protected.
I would strongly urge you to run at least one new circuit for the receptacles in order that your tools are on a different circuit than the lights. It can be dangerous to "trip" a circuit breaker feeding lighting while using your tools.
Received 0 Votes
Didn't want to get into it, but I do have a 15a circuit for the lights already but I certainly will extend that circuit to the workshop lights.
One other potential problem I've come across...is there any good way to protect the romex wire while it's inside the wall? I'll be hanging A TON of stuff off the drywall so I'll probably be punching many holes. I'll put the metal-plate stud covers where appropriate but is there a decent way to protect the romex wire stapled inside to the stud? Will a simple plastic/metal conduit do?
I would try and route the cables at heights where you are not likely to install hangers.
If you are going to use conduit it will be easier to use individual conductors.
Furd is correct. They must be above 18" in a garage. I like to put them at 48" for ease of access due to the crap that tends to get piled along walls.
Never heard of such a thing in the NEC.:NO NO NO: Unless the 2011 has it?
Around me it is enforced similar to a commercial garage because it can be assumed there will be flammable liquid (gasoline) stored in a garage. It has been that way for a very long time.
Received 0 Votes
As an example, I'll be screwing a ton of shelf brackets into the studs. I didn't want to miss a stud and screw right into a cable. Obviously, using shorter screws is the best option there.
Now the near edge of the cable is 2 1/8" from the face of the wall. Do you need screws longer than 2"? Those would give you 1 3/8" into the wood.
And, as pcboss commented earlier,
I would try and route the cables [for cross-wiring] at heights where you are not likely to install hangers.
