Outlets working but not light fixtures.
Received 0 Votes
Not sure where to go with this. All of the outlets in the den work but suddenly the ceiling fan and the other light fixture as well as the exhaust fan over the stove do not work. I replaced the switches but that didn't work.
I bought a tester so that I could test the breakers and they all were receiving power but for some reason, there was no power at the switches.
Don't really know why all of a sudden they would just stop working.
Any help or suggestions are greatly appreciated.
Thank you
Thank you
Follow Mitch's instruction to reset the breaker and we will go from there.
Received 0 Votes
Ok. I will make sure that all of the breakers are in the right position and are not tripped. For clarifiction, do I flip them off and then back on, or just make sure that they are flipped on? sorry if that's silly question, just want to make sure that I am doing it the right way.
The tester that I was using (I don't have it in front of me) had two contact leads, a black and a red. The guy at Home Depot told me to use it to see if I had power at the breaker. ok.
Thank you guys for the responses. I am checking the breakers now.
Have you red this yet: http://www.doityourself.com/forum/el...rminology.html
You did test between the breaker screw and neutral bar correct?
Received 0 Votes
OK. I flipped all of the breakers off and then back on and nothing happened. still no power is getting to the ceiling fan, light fixture or exhaust fan.
I am not familiar with a solenoid tester. I will say this about my electrical panel; There is not a main shut off for all breakers. There are 2 thick main cables coming into the panel that are screwed down. I don't know where the main shut off would be.
Thsnks again
Thsnks again
Is it possible that lights and fan were fed off one of the outlets that was a ground fault and was tripped.
I had a lightning strike about 200' away and surge through the Comcast cable was enough to burn out the TV (smoke and all). Later, I just happened to look at an outlet in the kitchen and noticed it had popped - All were wired by the amateur DIYer that was the father of the slumlord that previously owned the townhouse.
Anything is possible.
Dick
Dick
Received 0 Votes
ok, silly question. Where would the exhaust fan recepticle be at and how would I get to it? Sorry if dumb question but we have been living with this issue for 7 months as I have tried and various trouble-shooting ideas and asked around.
As for getting to the boxes where the ceiling fan is, the access to that part of the attic isn't big enough for a 5 year old to climb into.
Thank you guys for your continued suggestions. I need it.
I will definitely look around for one of those. There is one in a bathroom off the kitchen. I tried that and noting happened but I will see if there is another one hidden some place.
If the exhaust fan is turned on by a wall switch, that's another place you could have lost the power.
Received 0 Votes
Good point. I guess I should say that they aren't working but that I am not getting power at the switches.
The exhaust fan is the light and fan combo without the microwave deal attached. When I pulled the stove away from the wall I only saw the one main plug for the stove so I am assuming that the exhaust is wired inside the wall someplace since the stove is new and I did not see the installers do anything as far as wiring the exhaust fan.
You said that there should be 2 GFCI recepticles in the kitchen. If I do not see them, what is that an indication of? Aside from me being blind. Would they have "hidden" them someplace?
I will take a look at the box for the ceiling fan. How exactly should I test that once I have accessed it?
Did you open the exhaust fan and look for a connection. If you're not sure how post a couple of pictures of the outside and looking up into it. http://www.doityourself.com/forum/li...-pictures.html
#25
Received 0 Votes
ok. I actually took the wxhaust down and noticed an ugly hole in the wall where they ran the power wire back into the wall. There is not receptacle on the other side so my guess is that it's hard wired in to the receptacle where the stove is plugged in at. Could that be the case?
As for the gray box, how will I know what 'm looking for when I take the cover off.
Thanks for the continued help.
#26
#27
Just remember you can get a false positive from a non contact tester so it is no guarantee you have power. On the wire nuts you need to remove and replace with new or at least check the insides for corrosion.
#28
I've had difficulty using my non-contact tester to tell which wire was hot. It's not really the best tool for that. But I've never had it light up and ring steadily when there was no power. IMX.
#30
The non-contact detector will not tell you if the neutral is missing due to a failed connection.
#31
Received 0 Votes
Great. Thank you guys for the information. I will take a look at it tonight and when I get home.
Another question I have is about my electrical panel. When I take the main cover off, the panel does NOT have a main shut-off. There are only 2 main cables coming into the panel that are connected at the top by screw down terminals.
1. How do I turn all the power off?
2. Should there be a main shut off somewhere else?
3. Is this kind of panel up -to-date?
Thank you guys so much for your assistance. I just want to make sure I do everything right.
#32
#33
#34
Received 0 Votes
I do. When I take the cover off there are (going off memory) 5 -7 breakers on each side and the what I'm guessing are the ground wires connected inside the panel but on their own terminals so yeah it looks like the ground and neutral wires are connected to a seperate bus bar.
I have never seen another "panel" anywhere in the bsement. I THINK the house is older than 60 but I will confirm later.
1. Why is that done? and
2. What if I don't see another meter socket or breaker panel?
When I get home I can take a pic so that you guys can see what I'm seeing if that will help.
Could it be that there is another breaker on this other panel that has tripped and is causing my issue?
#35
Yes, Pictures would help. Please include a picture showing the area around your meter, the area around your breaker box, and a close up of the inside of your breaker box. http://www.doityourself.com/forum/li...-pictures.html
There should be only one meter. Since your location is Tennessee I'd expect it to most likely be outside but maybe not.
#37
Received 0 Votes
The house was bult back in the 80's.
Here is th link to the pic of my panel.
ImageShack® - Online Photo and Video Hosting
#38
Thank you, but it would be more helpful if you would follow the instructions in How To Include Pictures, so that your images appear in your posts. It would also help us if you would post the pictures of
that Ray asked for.
Looking at this picture, I think I'm looking at a distribution panel with 20 or more circuit breakers, no main OCPD - two feed lugs instead - and the neutrals and grounds all tied together. Is that right?
the area around your meter and the area around your breaker box
#39
Received 0 Votes
Sorry about that. I will make sure in the future that I include the pic in the actual post. I will also take more pics of the surrounding area, I had just gotten home but I understand. Thank you.
You are correct in your analysis of the panel. So does that mean that somewhere else there should be another "panel"?
#40
the area around your meter and the area around your breaker box.
