Driveway lights controlled from two switches - can I convert to only one switch?
I am installing Honeywell RPLS7408 to control my porch light.
I would also like to install the same timer to control my driveway lights, but those lights are wired to two switches. One in garage and one next to the porch light switch.
Is there any way to convert the wiring to single pole circuit so that only the front door location controls the lights so I can use this timer?
This is a great forum and any help is greatly appreciated.
Welcome to the forums! First, at your switch location at the front porch is there a bundle of white wires (neutrals) bundled up and poke back in the box? You must have a neutral in the switch box in order to use this timer. Since you have three way switching, can you tell us the colors of the wires to the switches. It will help us to tell you which wires to cap and which ones to connect together to make only the porch location work.
Thanks for the quick reply.
I do have the Neutral bundle and I ran a pigtail to the porch light timer. That is working as it should.
The two way switch has Red, 2 Black and Ground wires. I want the driveway lights to be independent from the porch light, but only be single pole and get rid of the garage located switch. I am including picture.
An aside to Ray. Looks like line is on this switch from what I can trace. The wirenut just over the hallway switch appears to power it all. Hopefully only load is on the other one. Is that what you were getting at?
Sorry for the late reply. I was fixing the sprinklers and changing to rotator nozzles today.
Ray I am a newbie when it comes to electrical wiring so I am lost at which is common (is it line?) and which is a traveler (is it load?).
Boss I need to abandon the garage located switch because the timer is only single pole connection. There is no way to wire it with companion switch. Or is it?
Here is another picture that shows little bit more detail. If you need me to untangle the wires inside let me know and I will do that.
I do appreciate your help.
Here's what I think. I'm agreeing with chandler's argument that the wire on the point terminal on this 3-way is the line feed. I'll add to his argument that it appears, from what I can trace, that the 3-wire cable connecting this switch to the one in the garage enters the bottom of the box between the first and second switch locations, and that the white wire from that cable is tied into the neutral splice.
If we're right about that, then here's the question: Do you want to have the driveway lights controlled only by a timer in this box, or only by a timer in the garage, or do you want to have the timer in one of those locations and a "kill" switch in the other?
I think it's the first option, both from what you said and the fact that the timer wouldn't turn the lights on unless the "kill" switch was also on. But I thought I'd ask to be sure.
Here's my take on what I think you want. Remove the red wire on both switches and cap them. On the garage switch, take the two remaining blacks and tie them together, removing the switch entirely. Connect your timer with a neutral to the neutral bundle and to the remaining two black wires (one line and one load). If the timer requires you to dedicate one of it's wires to the hot wire in the switch, use the one from the wire nutted black ones in your triple gang box, as it feeds everything. the other black will go through to the light directly. Use a plain cover plate on the switch in the garage.
Chandler, it worked just like you suggested.
I removed the switch in garage, capped the red wire and twist tied the two black wires together. Then I capped the red wire by the front door and connected the black pig tail from the line to the line wire on the switch and hooked the white neutrals together from both switches and ran pigtail to the neutral bundle. Finally I connected the black wire going to the light with the blue load wire on the timer.
Works like a charm. Now I can turn on both the porch and the driveway lights 30 minutes after sunset and can turn the driveway off at 23:00 and the porch light 30 minutes before sunrise. No more porch light in the middle of the day when dark clouds come (had photo sensor on each light bulb).
Thank you all who replied with their input to this electrical/wiring newbie (although my son & daugter stand in awe and speechless
I hope that I can reciprocate alas probably in the automotive forum.
Here is pic of the finished product.
