Light won't turn off
Received 0 Votes
I was changing a light in our sunroom and after it was changed the light will not turn off. in the wall there is a black, white, red, and ground wire. On the fixture there is a white, black, and ground wire.
I put black to black, white to white, and grounded the wires together.
I also looked at the switch and there are only black and red wires running off of the switch.
Any help is appreciated!
Did you change the wiring at the switch? Is the fixture operated by two switches? If so, check the position of the other switch and make sure it is either completely up or down.
Maybe I misunderstood something. Is this a wall-mounted fixture? And when you say
are you referring to the wall box the fixture mounts on?
If so, then you probably need to connect the black wire on the fixture to the red wire in the wall - not to the black wires.
in the wall there is a black, white, red, and ground wire,
I'm getting my bearings on this, too. I would cap the black in the wall, hook my black from the fixture to the red, white to white, gnd to gnd. You may find there is something else not working once you hook this up. We'll wait till you find it....like a receptacle or something.
Your neutral wire is grounded before the light switch. Power will travel through the light bulb and continue through ground instead of being stopped at the light switch
All neutral conductors are "grounded ahead of the switch" or the receptacle. If they weren't, they wouldn't be grounded conductors, which is what neutrals are. When we open a hot-to-neutral circuit by unplugging the load or "turning the switch off" on the ungrounded conductor, the light turns off.
'Do you have a different way of explaining what you meant?
