120 or 240
Old 04-15-12, 07:48 AM
120 or 240
I have an old norman pottery kiln I want to use, it says its 115 volts 24 amps phase 1, it has the original plug which is the old dryer type 3 prong with one L shaped, but that outlet is 240v this is confusing me, inside the unit 2 wires go to seperate heating elements then go into the same control switches the 3rd wire is grounded on the case Thanks
Old 04-15-12, 08:21 AM
Tolyn Ironhand's Avatar
Somebody likely put the wrong cord end on it because a 240v 30 amp cord cap is more common then a 120 volt 30 amp one. If the unit says 120v, I would get the proper cord cap (120 volt/30 amp) and wire it for 120 volts.
Welcome to the forums!
Old 04-15-12, 10:06 AM
ray2047's Avatar
Old 04-15-12, 11:01 AM
120 or 240
this is the 2 v prongs with 3rd top middle prong is L shape like old dryer, whats strange is i got it from the son of original owner that bought it in 86 and never used it, cant see why someone would change a plug on a new kiln, before i bought it had owner unplug his old dryer (in old house) and he plugged it in and we let it run for 20 min. to make sure it heated up, didnt check outlet voltage and lost his nu.
Old 04-15-12, 11:33 AM
ray2047's Avatar
It is possible the two elements have been wired in series for 240v. Does one side of the line in go to one element and the other line in go to the other element and then the other ends of the elements go to the switch.? Is there a nameplate on the kiln? If so try Goggling the model number for more info.
Old 04-16-12, 08:30 AM
120 or 240
I put a subpanel in and wired it for 120 with a hot, nu, and ground and it works fine thanks for response
Old 04-16-12, 05:06 PM
Good! Glad to hear it! I happy you did not put 240 volts to it otherwise you would have burned up a bunch of stuff!
