Can this motor be rewired for 240 VAC?
Old 04-15-12, 12:58 PM
N
I'm wondering if this motor can be rewired to run on 240 volts, so I can lower the amperage. http://images5a.snapfish.com/2323232...A8534%3Anu0mrj
Old 04-15-12, 01:38 PM
ray2047's Avatar
You did not include a proper link. http://www.doityourself.com/forum/li...-pictures.html
Old 04-15-12, 03:33 PM
Tolyn Ironhand's Avatar
Received 861 Upvotes on 724 Posts
No. This motor is only a single voltage motor as listed on the nameplate.
Why do you want to lower the amps?
Old 04-15-12, 06:39 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
And you won't be saving anything by lowering amps. Ohm's law shows as voltage increases amperage decreases, and vice versa. You will still have the same wattage being used regardless. I run all my shop tools that allow it on 240 volts, but purely for a faster spool up and less bog down feature. I pay the same.
Old 04-15-12, 07:29 PM
N
The reason i was hoping i could lower the amps, is because the sub panel is 230 feet away. I thought if I could cut the amps in half, I could use smaller conductors.
