florescent burning out
Old 04-17-12, 12:10 PM
F
I have a hanging light that hold three bulbs. I have replaced the standard bulbs with florescent bulbs. They tend to flicker often and burn out quickly. So I removed the fixture and rewired it completely, thinking that could be the issue. No go! They still flicker and burn out fairly fast. The wall switch is a dimmer type and I am ready to replace it next. ( though we keep it fully turned on )
Any ideas why?
Old 04-17-12, 12:17 PM
Nashkat1's Avatar
Received 2 Votes on 2 Posts
Probably the dimmer. You could replace it with a fluorescent-compatible dimmer or a regular switch. The only other thought I have is reversed polarity, but that shouldn't be the case here since you rewired the fixture.
Old 04-17-12, 01:06 PM
Received 94 Votes on 83 Posts
As a general rule, CFLs don't like dimmers.
Old 04-17-12, 04:38 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
The dimmer is the issue. Fluorescent lights also do not play well with lighted toggle switches or motion sensor switches.
Old 04-22-12, 07:32 PM
F
you got it!
changed the switch and that cured the problem - thanks all.
Old 04-22-12, 09:57 PM
Nashkat1's Avatar
Glad you solved it. And thanks for coming back to tell us how it worked out.
