Outlet No Longer Working
Received 0 Votes
I have a garage and bedroom separated by a wall the garage side and the bedroom side both have wall outlets. Both recently quit working. I flipped all the breakers off then on and it did nothing. What is the next thing I look for?
-There has been no excessive amount of electricity flowing through these lines
The garage outlet should be GFCI protected. It's possible that the bedroom outlet on the same wall is tied into that. Have you tried resetting the GFCI protection for the garage receptacle?
Received 0 Votes
I have no idea what this is or what to look for. Picture this, there is not much distance between the breaker box and this particular outlet, it is all covered by drywall though. Picture the walls forming a T the outlets are at the base of the T on both sides and the breaker box is at the top left side of the T on another wall.
Remember to look behind boxes, cabinets, and furniture that haven't been moved in years. Check all outside receptacles and all bathroom receptacles. If you have a basement or crawl space look there.
Received 0 Votes
I have identified 3 outlets that no longer work, the one closest to the breaker box doesn't work either. I am having trouble finding a GFCI receptical. With the outlet that is closest to the breaker box I believe I see the main wire powering it coming up into the garage attic. There is a peg board in the garage so it is hard to identify if there is a receptical behind it. Are all of them the same size as an outlet or light switch faceplate? Should I be looking only in the area between the breaker box and the outlet closest to it? May the GFCI be in the breaker box?
The breaker handle is used to reset it, there is only a test button.
