Remote control for 3-way light switch
Old 04-20-12, 09:28 AM
G
I have a fluorescent light hooked up as a 3-way. One switch is in perfect position; the other is not, but moving it is not an option.
Does anyone make a 3-way switch with an IR remote control? I would be fine with taking out the poorly positioned switch and replacing it with the IR receiver.
Thanks!
Old 04-20-12, 10:08 AM
Nashkat1's Avatar
Received 5 Votes on 4 Posts
Heath-Zenith, for one. Comes in White (SL-6023-WH) or Ivory (SL-6023-IV).
Old 04-20-12, 11:00 AM
ray2047's Avatar
Received 14 Votes on 12 Posts
Heath-Zenith, for one...
From their Tech Details:
Controls up to 300-Watt of incandescent lighting
Many of these type of switches use trickle feed through power from the device and won't work well with florescent lights. This seems to be one of those. The device you use must have a neutral and the box it is installed in a neutral if no incandescent lighting on the controlled circuit.
Could you explain more fully. Maybe there is a way you haven't thought of.
Old 04-20-12, 12:15 PM
G
I'm an optometrist. The lighting is in my office, which is a converted house. I would like to be able to control the lights from my work area which is along a 6 foot bank of external windows. Below the windows is a cast-iron radiator. There really isn't a piece of wall available to move the switch to.
Looks like the Lutron MRF2-6ANS-WH would work? Looks like they say it would work with non-dimmable fluorescents.
Old 04-20-12, 12:36 PM
ray2047's Avatar
From the instruction manual:
These electronic switches require a neutral wire for operation.
So yes they will work with a fluorescent light. Do you have a neutral at the box where you are going to install.
Note a white wire may or may not be a neutral. If power comes in at a switch then there is a neutral at that switch. Do you know where power comes in, at a switch at the light?
