My GFCI outlet keeps tripping when microwave oven is plugged in
Received 0 Votes
My GFCI outlet keeps tripping when my microwve oven is plugged in. There is also a regular toaster plugged in which does not cause trip. Both ae located near a sink, thus the GFCI. The microwave and toaster have been plugged into this outlet for over a year with no problems. Help please.
I see two possible problems. One possibility could be as simple as a bad GFCI receptacle. The second possibility could be a problem with the microwave oven. Since your toaster doesn't trip the GFCI, I am thinking it's a microwave oven problem.
You probably have a fault in the microwave oven. The GFCI receptacle detects ground faults as low as 5 mA so yes, it may work fine in a non-GFCI protected outlet, but that doesn't mean it doesn't have a problem. If the outlet you have plugged into is a non-GFCI protected outlet and it is on the kitchen countertop, it needs to be GFCI protected.
the microwave works on a regular outlet so I do not think it is that.
A GFCI is designed to open the circuit when too little power is being returned on the grounded conductor. In addition to the small amount of "lost" power required to trip it, the GFCI may open the circuit in only a few milliseconds. It depends on the amount of power gone MIA.
Totally different forms of protection. The problem sounds like it's in your microwave.
