Connecting guitar amplifier to basic car battery.
Old 04-29-12, 02:01 PM
Is is possible to connect a guitar amplifier to a car battery, and if it is, how would one do that?
Old 04-29-12, 02:18 PM
ray2047's Avatar
What voltage is the amp. If it is a 120v AC then you will need an inverter.
Old 04-29-12, 02:28 PM
Gunguy45's Avatar
Super Moderator
Not feasible...
A guitar amp runs off house current/voltage....120VAC. You might hook an inverter to the battery and get some use out of it....but I believe they make portable guitar amps that run on batteries...probably a better solution.
Old 04-29-12, 03:32 PM
Ray2047- Yes, it is a 120v AC, and thank you we found one.
Old 04-29-12, 07:56 PM
Sorry, Gunguy, my friend sent that post before I could delete what he wrote.
Old 04-30-12, 04:16 AM
When you calculate the power the inverter needs to deliver (in watts), make sure you use the amp's input power spec and not it's output power. A 100 watt Marshall, for example, will use over 400 watts of AC 120-volt power. The input power is usually listed on a plate or label on the back near the power cord. If the wattage isn't listed, multiply the rating of the fuse by 120.
