Need help to wire a capaciter to a electric motor
Received 0 Votes
HI, I've got a electric motor with 4 wires, 3 brown wires and one yellowand green wire. three brown wires have thre trgs on the edge, blue, brown, gray,
its a amp 3.8 rpm 2850 volt 220/240 motor, how can i do the wiring to the capaciter and what valtage capaciter should be? thanks, srijith100
Welcome to the forums!
I have moved your post to it own thread. It is always better to start your own thread rather then piggyback on another one.
Do you have a wiring diagram? That is the name on the motor? Please post everything listed on the motor nameplate. A picture might help too.
The cap should be at least 240 volts
Received 0 Votes
More Information,
Thanks guys, Unfortunatly i haven't got a diagram. ill try to uplord a photo of it as soon as possible, no its not a gear motor. kust a single phase motor, rpm 2850. thanks
OOps you are in Australia I see. I missed that so your standard RPM may be different. Can you post a picture of the motor? http://www.doityourself.com/forum/li...-pictures.html
Received 0 Votes
wiring for electric motor
Hi guys, thank you so much for your help, but still i work out about the wiring. finally i've managed to uplord some photos, hope it might help.
details of the motor are as follows,
Type - BC 2507/08
V 220/240
PH - 1
Hz 50
Wo 370
A 3.8
Rpm 2850
Ins Cl - E
Reg - Cont
Bs FRAME -B56
there are four wires coming out of the motor, blue, brown, silver, green/yellow.can some body advise me how to do the wiring for this motor, do i need a capacitor?
thanks
Type - BC 2507/08
V 220/240
PH - 1
Hz 50
Wo 370
A 3.8
Rpm 2850
Ins Cl - E
Reg - Cont
Bs FRAME -B56
