Romex in Mortar
Old 05-03-12, 04:54 PM
Romex in Mortar
Hi -
Newbie here. I'm mounting my TV on my brick fireplace (shocker!). For power, I'm considering channeling out the mortar and running romex from a nearby wall receptacle to a flush mounted receptacle behind the TV. Then, covering the romex with new mortar.
I've read a few articles about this, but my hesitation is this....is romex alone OK to bury in mortar, or do I need MC Cable with a PVC jacket?
Done all the heat tests on the brick, etc.
Any advice would be greatly appreciated.
Jim
Old 05-03-12, 05:30 PM
SeaOn's Avatar
-NM canít
-MC can
Just note, the cable must be attached to the box with a listed connector, and per code.
Old 05-03-12, 05:32 PM
CasualJoe's Avatar
No, you can't embed NM cable (aka romex) in mortar. You can, however, embed PVC jacketed MC cable.
Old 05-03-12, 05:35 PM
CasualJoe's Avatar
-MC can, but the location canít be damp or wet.
The MC still must be PVC jacketed. Aluminum MC cannot be used in direct contact with mortar (wet or dry) or any cementitious products.
Old 05-03-12, 05:40 PM
SeaOn's Avatar
I agree with Casual
Old 05-03-12, 05:43 PM
SeaOn's Avatar
Actually, it can be installed in wet locations where any of the following conditions are met:
a. The metallic covering is impervious to moisture.
b. A moisture-impervious jacket is provided under the metal covering.
c. The insulated conductors under the metallic covering are listed for use in wet locations, and a corrosion-resistant jacket is provided over the metallic sheath.
But this isnít the case, so itís a mute point.
Old 05-03-12, 06:02 PM
chandler's Avatar
Jim, at least you aren't doing what I found on one trouble shooting escapade. The contractor, a few years earlier had run UF cable under his concrete (not buried) for his steps to the lake. Needless to say the concrete shifted inequally with the UF. Had to run it all over again.
Old 05-03-12, 06:12 PM
SeaOn's Avatar
???? Doesn't under mean buried????
Old 05-04-12, 04:02 AM
chandler's Avatar
No under means laying on the ground with the concrete poured over it in the forms
Old 05-04-12, 08:39 AM
SeaOn's Avatar
WOW!!!!!!!!!!!! And Wow again!!!!!
Old 05-04-12, 10:36 AM
Thanks everyone. the trick now will be locating a local supplier.
