GFCI Dead
Old 05-18-12, 09:02 AM
Handyone's Avatar
GFCI Dead
I recently had a GFCI go out, won't reset. There was a power surge that knocked out my computer's Power Supply. Can a power surge knock out a GFCI? It's the SmartLock Pro Type.
Thanks
Old 05-18-12, 09:25 AM
ray2047's Avatar
Yes. It is like any electronic device it can be damaged by a power surge. If you have opened the GFCI and determined there are no loose connections and determined there is power to the line side using a meter or test light or solenoid tester but not a non contact tester go ahead and replace it.
Old 05-18-12, 09:32 AM
Handyone's Avatar
I'll replace it. I figured it was the electronics gone bad. This was a bad power surge we had and I'm lucky more stuff wasn't damaged.
Thanks
Old 05-18-12, 05:18 PM
CasualJoe's Avatar
How do you know you had a power surge? Are you using a recording meter?
Old 05-18-12, 05:36 PM
Handyone's Avatar
I'm not sure there was a surge, I just assumed
What happened was we lost power and then when it was restored, it went on and off about four times quickly, so I figured that wasn't good. It did blow out my computers power supply, or another coincidence.
Thanks
Old 05-19-12, 05:16 AM
CasualJoe's Avatar
It's possible you could have had some surges and most likely did. You are probably a good candidate for a whole house surge suppression device.
