Can you damage a mis-wired light switch
Old 05-18-12, 09:36 PM
H
I wired up a 3-way switch incorrectly (the other 3-way switch on the line was wired correctly). Upon energizing the line, the lights turned on. When flipping the mis-wired switch, the lights started to flicker and the switch started to make a poping noise (I assume something was arcing). The circuit is GFCI protected and it did not turned off. I subsequently de-energized the line and wired the switch correctly and the light now works appropriately. Is there any cause for concern with the switch or connected cable/wires?
Old 05-18-12, 09:41 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
I wouldn't be worried.
Old 05-19-12, 03:53 AM
Tolyn Ironhand's Avatar
Received 861 Upvotes on 724 Posts
Nope. The arcing was inside the switch. All switches will arc somewhat, especially if they are switched slowly.
