Bakrr: Meaning of 3 Wire
3 wire 120v to a single 20 amp breaker
3 wire would indicate 240v with a neutral wouldn't it?
3-wire in the field means 120/240. So: 3 wire=4 conductors>>>> two hots, one neutral, and one equipment ground. If you want a straight 240v, then you would have to be specific. The normal ordering of cable=14-3NMB/12-3NMB/ETC. ETC..
3-wire could indicate many things including 120 volt as the OP said. 240 volt doesn't have a neutral.
The thread where this appeared is gone
It is a Morgan Spa and the wiring scheme advises that it is a 120v (3 wire) cord connected to a 20 amp breaker
