Wiring to hook up irrigation pump
Received 0 Votes
Hi. I'm new to this forum and was wondering if someone could help me out with an electrical question. I have 220 volt pump that calls for a 20 amp breaker and want to hook it up to the disconnect panel box on my house that is fed by the meter. The disconnect on the house is a 200 amp breaker and I was thinking I could install a 60 amp breaker in that disconnect and then have another disconnect at the lake with a 20 amp breaker. I've already run the wire which is 500 ft of aluminum underground AL 2-2-2-4 (two hots, 1 common, 1 ground) from the disconnect on the house to a disconnect I want down by the pump. From the disconnect down at the lake, I want to run 12-2 underground from there to the pump. The question I have is in the disconnect box on the house there is only one bar which has a ground connected to it.(Please see picture). Do I connect the common and ground to this bar or do I need to install another bar, or would I connect the ground wire from the disconnect at the lake to the ground rod at the house? At the house there is a ground rod in the ground which the disconnect on the house is grounded too.
Thanks,
Tony
Thanks,
Tony
At the subpanel, you need two bars, the ground bar bonded to the panel and the neutral bar insulated
Now that I look at this more closely, I'm not certain you can put a 60A breaker in this panel. You could end up pulling 260A from your feeders, which they likely aren't rated for. Also, I'm not sure why you have a 4-pole 200A breaker...
