Over Heating Desk Fan
Received 0 Votes
I recenly bought a small 6" brass blade single speed antique GE desk fan and the wiring was worn out. I had to remove the rotor to get to the area where the wires were connected and I thinlk I crushed both carbon brushes when I reinstalled the rotor because I forgot to remove them when I removed the rotor. I purchased some replacement carbon brushes and when I plugged the fan in it is a little noisy and it is overheating (smoking).
What can I can do to eliminate the overheating?
Thank you
Thank you
It could be that the fan was originally discarded because of the overheating problem. I don't know how old you are but I am old enough that I remember when such fans were common, not antiques. Back then they ran so hot that if you were to touch the motor after it had been running for a while you risked a serious burn. If someone over-oiled the bearings it could be the oil burning from being in contact with the motor windings.
Received 0 Votes
I plugged in the fan when I got it and even with the power wires barely hanging on it worked and was quiet. I ran it for an hour today and I would have thought the brushes would have worn in by now. I put directed another fan on the back side of the little fan when it was runnung and it kept it cool.
I did oil it but I would have thought it would have burnt off as hot as it got.
I hate to take it apart again because I can't get the brushes out of the fan and I will probably destroy them again at a cost of $15 /pair.
Any additional ideas on how to stop the overheating?
Thanks
Thanks
Received 0 Votes
I found the brushes in small pieces when I was reinstalling the rotor. I bought the kind of brushes that have a wire and spring attached but they wouldn't reach the rotor so I cut off the wire and spring and used the small springs that were originally in it that look like a spring from a ball point pen.
I just slid both brushes down the small openings in both sides of the motor. One of the plastic caps that originally held in the springs/brushes in had been replaced with a metal tire air valve cap so I found another one so both caps would match. The guy at the motor repair shop where I got the brushes said he "thought" the caps would be okay to use. I don't suppose the caps could be causing the overheating??
Than you
Than you
