Replacing a breaker with GCFI breaker
Old 07-17-12, 04:48 PM
Nashkat1's Avatar
I noticed that one of the motors have a single green wire coming off it. No mention of it in the manual. I could only assume it's ground, however, where would I attach it to?
Interesting question.
My intuition would be to connect it to the nearest source of ground - bonded frame, the GEC in one of the power cords - whatever's handiest.
Old 07-17-12, 04:50 PM
The hot tub sits on a steel frame. Would it make sense connecting the wire to the frame, or it's better to connect it to an outlet ground?
  #43
Old 07-17-12, 04:57 PM
Nashkat1's Avatar
It doesn't matter. What matters is that you connect it in a way that bonds it to ground. Is the steel frame bonded to ground?
  #44
Old 07-17-12, 05:07 PM
i guess not. This is an enterior unit that stands on a wood floor. So i guess i just attach it to the ground in the plug. Not a problem.
  #45
Old 07-18-12, 05:27 PM
The ground is actually coming off a heating unit and per call to the dealer, the ground should be attached to the tub's steel frame. Does that make any sense, since the frame never touches the earth?
  #46
Old 07-18-12, 06:43 PM
Nashkat1's Avatar
Yes.
You and I don't know what that frame is bonded to. It may well be bonded to earth (ground). Frankly, if I was building these, and didn't want to be sued out of business, I would make sure it was. That you and I can't easily see how they did that doesn't mean that they didn't. It just means that they may have been slick about it.
When is the dealer going to provide you with the hard copy of the instructions that support his statement?
  #47
Old 12-10-12, 10:58 AM
controlling with light switch
I have been using the sauna about once a week this fall, and it is great! The manufacturer recommends shutting the power off completely when not in use, to conserve energy, so have been turning it off at the breaker after each use.
The 30A GFCI breaker that controls the steamer and all electronics is pretty rare and expensive, and I'm worried about wearing it down prematurely. I was thinking of wiring and using a light switch instead. Does it have to be any specific switch with 30AMP 120V rating? Or since the unit is turned off at the control board and doesn't draw any power, any generic light switch would do?
  #48
Old 12-10-12, 11:11 AM
pcboss's Avatar
Probably a lead to be spliced to the bond grid under and around the tub.
  #49
Old 12-10-12, 11:28 AM
The way it's set up is all the wiring is behind the unit and runs through the crawlspace into the panel in the basement. I would like to wire a switch right after it leaves the panel. Again, the switch does not turn on the sauna, just the power to the control board.
I think I understand that I need a 30a rated switch.
  #50
Old 12-10-12, 03:26 PM
Here's a silly question, can I use a double pole 30amp switch for a single pole wiring?
  #51
Old 12-10-12, 04:23 PM
Nashkat1's Avatar
Sure, but why would you want to? DPST or DPDT?
  #52
Old 12-10-12, 04:56 PM
I was thinking more like this:
30-Amp Industrial Double Pole Switch - White-R52-03032-2WS at The Home Depot
I already have a box in that location, just need a switch and I can shut it off, instead of the breaker.
  #53
Old 12-10-12, 05:21 PM
CasualJoe's Avatar
The double pole 30 amp switch you linked to would work fine, but all you really need is a single pole switch. Ask if they have one.
  #54
Old 12-10-12, 05:24 PM
Ebay has the 2 pole for $4, but single pole for $5. It's a bargain.
  #55
Old 12-10-12, 06:49 PM
Nashkat1's Avatar
OK you got me. For a minute there I thought you had a serious reason for asking.
