what do i need for parts
Old 06-09-12, 09:42 AM
We have one well 65ft. deep between two cabins we both have pressure tanks and controls in each cabin the power is run to the well from each cabin. we live in our cabin in the winter and he live in his in the summer. We wire the pump each time we change who is there. Is there some switch that we can install so that we can just switch the switch instead of rewireing each time.
Old 06-09-12, 10:24 AM
The parts
It's called a double throw switch, depending on wether the pump is 120, or 220. It would be single pole double throw. or double pole double throw. If you asked this question in the electrical forum, you will get an answer there also.
Sid
Old 06-10-12, 12:16 PM
Why not just install a plug? Just switch from one plug to the other. I've done it many times (installed a plug). Just make sure your plug is rated for the HP/amp draw of the motor.
Old 06-10-12, 12:48 PM
Tolyn Ironhand's Avatar
Moved to electrical section. Though, the info you have been given is good, somebody else might have something better.
Note: if you did install a cord and plug, a in-use cover would be required.
