AFCI Pigtails.
AFCI Pigtails.
I have to install approximately 20 Afci's in a QO panel. The problem is, all of those neutral wires are too short. What do you guys usually do to extend them? I was thinking of splicing 4 to an 8AWG wire, in a blue wirenut, but I'm not sure if the AHJ would pass it or not. What would you guys do? Thanks once again.
I'm SO glad we're still on 2002 code here and we don't have to waste that much money on those stupid things.
That place must be a mansion! Your problem is what I suspected a lot of electricans would run into with the latest codes. That, and a real mess of pigtails. Although I think your suggestion would work, I would consult the AHJ before continuing. I don't see how splicing 4 pigtails to a larger conductor would be much different than combining all the pigtails on the neutral bus, but that is just my opinion. Cutler-Hammer foresaw your problem when they developed their CH series loadcenter with the plug-on neutral bus specifically for multiple AFCI breakers, the AFCI breakers for these new loadcenters have no pigtail.
Received 38 Upvotes
Do the AFCIs have stranded neutral pigtails? Some do. If stranded then I would use insulated butt connectors crimped on with sufficient lengths of white THHN stranded wire in the appropriate size. Don't use the butt connectors with solid wire.
Tomorrow, I'll pick up a spool of THHN and a pack of butt splices.
Note: My only relationship to Klein tools is as a customer.
Justin, If you don't already have one, you might want to pick up a Klein 1010 when you get your materials. I don't remember now when I first got mine, but it's become my go-to tool for a lot of work - especially for stripping and crimping butt splices and terminals, 'cause I can do all the steps with one tool and it puts the leverage where I like it.
