12 volt clock
Old 06-18-12, 03:50 PM
12 volt clock
I have a 12 volt clock that keeps resetting to 12 o'clock. I have the black wire on ground, the red wire straight to the battery, and the yellow wire to the key. if i switch the red and yellow wires it does the same. How do i fix it to stay on time,but go out when I turn the key off?
Old 06-18-12, 04:20 PM
Gunguy45's Avatar
Super Moderator
Normally the yellow is the constant power source, I least that's what I've found, so I would think you have tried all the things you can. If it's a used item...maybe that's why someone got rid of it.
Did it come out of a vehicle? Do you know the make and model?
