G.F.C.I with no grounds
Old 06-18-12, 06:37 PM
bobbi 5's Avatar
Okay, a question for everybody. so how does a G.F.C.I installed in front of some nongrounded outlets protect them if you need a ground to even trip the g.f.c.i
Old 06-18-12, 06:46 PM
Tolyn Ironhand's Avatar
You do not need a ground for a GFCI to work correctly. It measures any imbalance between the hot and neutral wires (or hot to hot if a two pole). IF it detects an imbalance of 4-6mA it will trip.
Definition: A ground fault occurs when electricity travels outside an intended path and tries to get to the ground by the shortest route. IE: through you!
Old 06-18-12, 08:15 PM
bobbi 5's Avatar
how can an inspector test that circuit down the line to make sure it is working.
Old 06-18-12, 08:47 PM
Nashkat1's Avatar
The same way you can. Stick a GFCI receptacle tester in it and push the test button. If the LEDs light up in the "correct" pattern and the GFCI trips when the button is pushed, all is good.
Old 06-18-12, 08:58 PM
bobbi 5's Avatar
it wont trip without a ground
Old 06-18-12, 09:03 PM
bobbi 5's Avatar
your tester wont trip without a ground. so if the inspector wants to test it down the line he has to short your hot to ground or is their another tool.
Old 06-18-12, 10:40 PM
SeaOn's Avatar
True (it want trip), so tell the inspector to use his or her finger to press the test button. If the test button turns off, and kills power to everything connected down stream, then you are good.
Old 06-20-12, 05:41 AM
pcboss's Avatar
The built-in test button is the only recognized method to test a GFI or AFCI.
