king craft 6000 gen
Old 07-01-12, 07:30 AM
king craft 6000 gen
it worked fine the last time i used it but the on,off switch broke. i replaced the switch and gen started up. my problem now is i have no power to any off the outlets. checked all wiring connections can't find problem. item#1705 serial#jd 3900ty 130310. appreciate any feed back
Old 07-01-12, 09:21 AM
Tolyn Ironhand's Avatar
There might be a fuse or circuit breaker someplace that has blown. You will have to take things apart and check them with a meter.
Old 07-01-12, 09:30 AM
Gunguy45's Avatar
Super Moderator
Might also require a "flashing" if it's been a while since it was used. Can't tell you the exact procedure....some are complicated...some just require a tool like a 120V corded drill plugged in and spun.
Old 07-02-12, 02:20 PM
drill check
tried that but it was us,ed about 6 months ago. it dont make any bad noises like something is stuck
Old 07-02-12, 02:23 PM
ok i'll try that thanks . i guess i'll just have to start it and start testing
